1 - 8 of 8 Posts
· Registered
Looks like I will need to contact Xemodex to get my ETM repaired, I got the ETS light with the check engine light. I know what I will be doing this weekend! The code was P0121 throttle position sensor.. :mad:
· Registered
I have everything out of the way but there is a small problem..the ETM plug is routed behind the starter, do I have to remove the starter or is there another way other than cutting the plug off. :facepalm:
· Registered
Thanks Precopster, That worked and now it is out and packaged up to send off to Xemodex, It is a white tag, I think that means that it has never been removed and I doubt if it ever had he recall done. I will post more later.:D
1 - 8 of 8 Posts
