Re: Dead Steering Wheel Controls revived; Kudos to Oceans60r (MrTippy)
I should have phrased the key being in position II allows the correct boot order of the entire network vs the key NOT being in Pos II or not in at all. Only select modules have power w/o the key in II.
I'm glad it worked out for you.
I would suggest there is probably a Software Update for the SWM that helps deal with this. http://********************/smile/emthup.gif
Quote, originally posted by MrTippy » |
He also noted: Reason for the key in position II was that the factory trainer said it allowed all the modules to get power at the same time vs some only getting power when the key is in position II. So it allows the network to boot in order and ping all the modules. It won't hurt anything doing this." |
