1 - 6 of 6 Posts
I'm looking to install an aluminum dead pedal and wanted to know from those of you that have installed them how to go about it exactly. What's behind the carpeting - can I just use self-tapping screws and do i need to worry about hitting anything critical?
Re: Dead Pedal Installation (Thesaurrex)
Quote, originally posted by Thesaurrex »
There IS a cable harness there, but it is protected by a hard plastic sheathing and 1/2" of soft foam. If you are using the takspeed pedals/screws you can just drill into the rubber footrest until the bit pops through the outer rubber, then use the screws. I also used a little double sided tape on mine to hold it in place even firmer. http://********************/smile/emthup.gif
Re: Dead Pedal Installation (Mash)
I also just bolted the pedal to the carpet basicly.
Just be very careful you don't drill or run a screw through the wire harness that is under the carpet.
1 - 6 of 6 Posts
