So it all started when I realized my driver side floor was flooded cause the freaking water evacuation tube from the sunroof disconnected.
I disconnected the battery, removed the driver and rear seats, disconnected the waterfall console and opened everything to let the carpets dry for a couple days.
When everything was fine, I put everything back together, connected the battery and started the car to realize that nothing of the instrument panel, climate control or radio works.
The check engine light works and I can sometimes hear the disc changer trying to find a cd but nothing else. The DSTC button doesn't light up either. Everything else works: blinkers, windows, sunroof, fog lights, interior lights...
I didn't check the fuses since I don't really know which one I should look at .. And I feel like a blown fuse wouldn't create all these problems but I'm really not the person with the biggest knowledge when it comes to cars so I might easily be wrong.
I was wondering if someone could tell the problem just by the symptoms and if there could be some easy fixes to try? I don't want to spend a ton of money since I just want to sell it asap.
Sorry if there is a lot of mistakes, english isn't my first language.
Thank you and I wish you all a good day!
