Hello,<p>is it possible to deactivate the AWD system on a ´98 V70-R AWD?<p>Ive heared that you can deactivate it by the S60/V70R 2001+ by removing a fuse or something like this. Is that also possible with the 98 VR?
Re: Deactivate AWD 98 VR70 (stump-R)
Remove the driveshaft<br>(This is the only way)<br>The other would be <B>2003 </B>and newer (Haldex equipped)
Re: Deactivate AWD 98 VR70 (JRL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>JRL</b> »</i></TD></TR><TR><TD CLASS="quote">Remove the driveshaft<br>(This is the only way)...</TD></TR></TABLE><p>Or to retain stock under-body appearance -- remove the viscous coupling from the torque tube -- retaining carrier bearing, torque tube body, and driveshaft. (Store the coupling in the trunk.)<p>This may be the best method if the angle gear is still good. It allows reactivation of AWD in the future by simply replacing the viscous coupling cartridge -- the rest of the AWD components will still be on the car. No need to go looking for that misplaced driveshaft...<p> <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/embeer.gif" BORDER="0">
