1 - 6 of 6 Posts
Dear all,
I have read the dashcam threads and see ppl hooking up the dashcam.
I want to hardwire mine too. I got the hardware kit from amazon. But which fuse slot should I plug in?
I will tap it to the passenger side's fuse box.
Can I use the empty fuse slot? and which amp should I use for the cam?
Thanks!
Dear all,
Thanks!
Don't have an XC60, but on on my S60, I used Power Seats for Battery (Always on) -Red wire and Heated Seats for Accessory (yellow) meaning this feature requires ignition from the car. Black is ground.
I just helped my dad hardwire a camera into his 2019 T6. I used slot 57/58 for constant (yellow). Either works. 49 for switched. (red)
Thanks guys!
What year XC60 do you own? I can pull up the manual and give you fuse numbers, if you'd like. Otherwise, you can reference the manual for the items I listed above.
Thanks a lot.
I checked the owner manual already. :)
hopefully, I can hardwire it this weekend.
1 - 6 of 6 Posts
