1 - 8 of 8 Posts
Id like to remove the dash possibly to install a Sub and possibly an Ipod transmitter. Does anyone know how to remove the Audio part of the dash? Is it possible to do it yourself?
Thanks.
Re: Dash Removal (turbo11)
DISCONNECT NEGATIVE TERMINAL OF THE BATTERY.
Pry out pen holder.
Push tabs on gear surround and pull out.
Remove Torx 25 Screws that hold the climate unit in.
Pull the bottom of the climate unit out and up.
The climate unit has to come off the two clips that holds it to the radio. You really have to pull out and up pretty hard on the climate unit until it releases. Don't be afraid, it is very hard to break them, and even if you do, everything will still line up.
Remove Torx 25 Screws that hold the radio in.
Done.
DO NOT RECONNECT THE BATTERY UNTIL THE CLIMATE UNIT HAS BEEN RECONNECTED.
Re: Dash Removal (dugums)
Quote, originally posted by dugums »
Amen. BTDT. If not, be prepared to pay the dealer to reset the SRS for you.
1 - 8 of 8 Posts
