1 - 12 of 12 Posts
I had a very brief flash from a dash light at the far LOWER RIGHT of the instrument cluster.
It was yellow and very small. (about the size or a teenie bit smaller as the warning triangle in the center of the dash) It went away too fast for me to see what it was.
Anyone, any ideas?
Re: Dash light flashing (JRL)
I guess DSTC indicator. Was it wet out?
Tom.
Re: Dash light flashing (Johann)
Quote, originally posted by Johann »
TRACS. You shouldn't drive that fast..
Thats happened twice when I was in wet conditions ... TRACS triangle as Johnann stated
Re: Dash light flashing (tmtalpey)
Quote, originally posted by tmtalpey »
Tom.
You sure.
A few times when I had it sideways,
all that flashed was the triangle IN THE CENTER between the tach and the speedo, this icon has never flashed
And, no, it was dry and I was going about 15 mph making a SLOW left turn in traffic.
As I said, in the 3 years I've owned the R this has NEVER flashed
I have seen a similar light flash briefly in the location you describe. It has flashed when I have been accelerating very hard and there is a sudden chirp of the tires. I think the others are correct in that it is the traction control telling you that it has lost traction.
You sure.
Well, the DSTC indicator (which also flashes for TRACS btw) is located in the lower right light cluster. It's a yellow triangle.
The big triangle with the "i" is a generic indicator which lights any time a message appears in the DIM. So, it might appear under similar circumstances. But a simple DSTC doesn't usually light that one.
You can get DSTC in all sorts of dry conditions as well as wet. My V50 flashes it when I drive onto speed bumps at 20+mph. I think the front wheels rising up the bump while the rears are still on the flat makes the DSTC think the fronts are starting to slip.
Here: http://apps.volvocars.us/owner...#pg28
Hey I learned something. The big red "i" in the middle is 2-colored, lights yellow for little things, red for big things.
Tom.
2019 S60 Pine Gray, M. Brown, Lin. Lime
That's not an "i". Its a bang "!"
whatever...
Re: Dash light flashing (MWH)
Quote, originally posted by MWH »
yes, THAT, is the traction control warning you; this is different than what JRL is describing
Well, it IS the DSTC light and I must have a bad sensor somewhere.
This has NEVER lit up in 3 years and now does so at, oh, 5 mph going out of my driveway
I don't think the DSTC works at that low a speed, at least it shouldn't.
It went in today for a 4K oil change (and my usual laundry list of small things to take care of), so that just went on the to do list
1 - 12 of 12 Posts
