1 - 6 of 6 Posts
Hello all,<p>The passenger side outer CV boot on my 96 850T Wagon is torn. I don't know exactly how long it has been damaged, but I'm convinced its been too long. Can anyone tell me how difficult it is to replace the entire axle? I found them for a great deal on fcp.groton. Do I need any special tools and is there anything else that should be replaced while I have the axle off? Thanks for any input.
Re: CV joint replacement eminent... (DogHauler)
You'll need a 36mm socket, and preferably an impact tool to get that nut off. The spline can be tough to get out of the hub. I use a mongo brass drift.. You also need to remove 1 bolt that retains the ball joint to the steering knuckle, and the axle bearing cap.<p>The job is pretty straight-forward.<p>I have an FCP axle in my '96 855T. It fit great <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
Time to download the 850 Service Manual! <br><A HREF="http://forums.swedespeed.com/zerothread?id=63818" TARGET="_blank">http://forums.swedespeed.com/zerothread?id=63818</A>
Re: CV joint replacement eminent... (atefitty)
As far as I was told, no boot kit
Re: CV joint replacement eminent... (JRL)
CV boot kits are available for all 850's and S/V'C70's<p>I have bought & installed 2 kits <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0">
1 - 6 of 6 Posts
