1 - 2 of 2 Posts
Took my 03 XC90 T6 AWD in for 90,000 mile service. Service Tech indicates that the boot is cracked and leaking grease which "might" flow through the hollow axle shaft into the transmission. So, they not only want to replace the axle and joint, but flush the transmission 2, possibly 3 times. all this to the tune of $1000.00 -- best estimate. <p>An independent guy says this is impossible. I believe that nothing is impossible with this car. I think I have (so far) replaced everything but the engine, transmission, and a/c -- literally!<p>Thank you!<BR><BR>
<i>Modified by pirategirl at 12:27 PM 8-10-2009</i>
Re: CV Joint leaking into transmission? (pirategirl)
Welcome to Swedespeed, Judy.<p>Try a new topic here...<p><A HREF="http://forums.swedespeed.com/zeroforum?id=27" TARGET="_blank">http://forums.swedespeed.com/zeroforum?id=27</A><p>Good luck.<p>George Dill
1 - 2 of 2 Posts
