Hello,
I am trying to install a Parrot MKi9200. I have bought the CT10VL05 (iso or T or whatever it is called) harness to do it. Everything has gone very well and it is straight forward with the exception of one thing. The Parrot has an output to mute the speakers during phone calls. The CT10VL05 does not seem to use the three optional mute wires referenced by Parrot.
Here goes an explanation: The Parrot harness has a single yellow mute wire output from the plug at the blue Parrot "blue" box with a standard wire terminal connector. The plug that goes into the CT10VL05 harness from the Parrot wire harness has three input"options" to connect that generic terminal to. Each "option" isn't even used on the CT10VL05. Therefore there is nothing to connect that yellow Parrot mute wire to.
I cant find a diagram or reference to the mute wire on my 2004 XC90. I have the premium system with navigation.
I am going to skip the mute wire for now until I figure this out so I can put things together and drive it in the mean time.
ANY HELP?
Before its posted: http://www.volvoforums.org.uk/archive/index.php/t-163441.html wasn't helpful.
ANY HELP?
