Hi all!<p>I received the IPD stabilizer bar PU bushings: <A HREF="http://www.ipdusa.com/ProductsCat.aspx?CategoryID=1798&NodeID=5594&RootID=629" TARGET="_blank">http://www.ipdusa.com/Products...D=629</A>)<br>and have a question regarding the washer that was included. It's not a flat washer, one side is has a sharp edge and the other side is rounded and smooth. For those that have installed this, which side of the washer butts up against the washer, the sharp side or the smooth side? TIA!
Re: Crossbar PU install question/help (mike_c70)
Usually the smooth side goes to the nut side<br>Happy vibes, (Vibrations). <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/rolleyes.gif" BORDER="0">
Re: Crossbar PU install question/help (bayflash)
Both of the above are correct. I tightened mine up to 38 lbs. Two weeks later I heard a rattling noise underneath the hood. I found it was the bolt I had tightened two weeks earlier. Retorqued them and all is fine. After the intial install give it a week and check them again. Just my 2c's
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>mike_c70</b> »</i></TD></TR><TR><TD CLASS="quote">Hi all!<p>I received the IPD stabilizer bar PU bushings: <A HREF="http://www.ipdusa.com/ProductsCat.aspx?CategoryID=1798&NodeID=5594&RootID=629" TARGET="_blank">http://www.ipdusa.com/Products...D=629</A>)<br>and have a question regarding the washer that was included. It's not a flat washer, one side is has a sharp edge and the other side is rounded and smooth. For those that have installed this, which side of the washer butts up against the washer, the sharp side or the smooth side? TIA!</TD></TR></TABLE><p>Hi Mike, <br>I got your voice mail abot this late Friday, but the last 2 digits of your phone # were cut off, sorry I was unable to get back to you in time. <br> <br>Also, our apologies that the instructions were missing from your kit, I'll check into that Monday. <p>The washers are to be installed so that they cup the bushing, "cup up". <p>Hope you got them installed OK. <p>If you have a moment on Monday , please give me a call at the office for an update on the springs etc. <br>Thanks,
Re: Crossbar PU install question/help (Scott Hart)
Hi Scott,<p>Thanks for your reply here. Actually, the instructions were included, it just never said what side of the washer butts up against the bushing. If you could revise that in the instructions, that would be helpful for others as well. <p>I'll call you on Monday. Thanks again Scott!
All cupped up, thanks for clearing the installation up, Scott and Mike for asking.<p>-Dan
