I have a 2011 V8 XC90 Executive Edition with about 156,000 miles. I got it right before the pandemic, so I haven't put too many miles on it over the last 2 years. The handling was alway very loose and it wandered all over when driving. Over the last 4 months I've put in new tires, B4 struts and shocks (including strut mounts and spring seats) as well as new outer tie rod ends, sway bar end links and finally last weekend I put on new lower front control arms and ball joints. Each thing has resulted in an improvement in handling. The control arms were the part that really tightened up the handling and eliminated a lot of noise. But I still have a creaking noise when braking and accelerating away from a stop. I could be wrong, but I think it is either motor mounts or subframe bushings. I figure for the subframe bushings I would try the poly inserts first before replacing them. Motor mounts are expensive and a bit of a pain, so I'm not running the parts catalogue right away.
Can anybody advise me if I'm heading in the right direction and which one is the best choice for next steps? Or point me in a new direction.
