1 - 8 of 8 Posts
This for a friend of mine with a '97 GLT with 160k on the clock. He is experiencing enough crankcase pressure to push out the dipstick. I am familiar with the flame trap on NA cars. What does the turbo use for crankcase ventilation and where is it located? He just had a new rear main seal put in the car and I don't want him to do that job again. I guess his mechanic should have addressed the crankcase ventilation issue first. Any advice appreciated. Thanks.
there should be a vent on the valve cover...or maybe a check-valve which leads to the suction side of the turbo piping.
The whole PCV system has be to cleaned and replaced. Not a good idea to run the car like that, especially if he just changed the rear main seal.
yah if the pressure is that great, im sure he is getting a LOT of blow-by.<p>also a great way to blow out your main seal! <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
Re: (TRQSTEER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>TRQSTEER</b> »</i></TD></TR><TR><TD CLASS="quote">The whole PCV system has be to cleaned and replaced. Not a good idea to run the car like that, especially if he just changed the rear main seal.</TD></TR></TABLE><p>I know- I told him to park it until it can get some attention. Thanks guys.
Re: Crankcase Ventilation Problem (Wayne T5)
The Breather Box is under the Intake Manifold. Same as the N/A.<br>Removed the intake Manifold to replace it. Also a good time to replace some nipples.
If you are some what mechanically inclined, this is a do it yourself job. Parts can be purchased together as a kit from places like FCP Groton.
Re: (Evil E)
Thanks. I changed the flame trap on my 850 a couple times but this is my friend's car and he lives a few states away...
1 - 8 of 8 Posts
