1 - 6 of 6 Posts
They are made for Jaguars but are a 5x108 and come in 18x8.5 ET42 and 18x9.5 ET25. They also make them in a 19" with the same widths and offsets. The only problem I see is that they are a 63.4 center bore, which I could have drilled out to the 65.1 that is required to fit the R right? You can probably guess what my question is on these; besides the bore size would these fit? Thank you in advance for your advice.
I accidently posted this in the classifieds last night :facepalm: so now im re-posting it here
The only thing you'd have to check is caliper clearance, which will be related to the depth of the barrel. I don't have an exact # for you, though with 9.5 you'll definitely need spacers to avoid rubbing.
Im confused. If I run a 9.5 and put spacers on it wont that make it rub more because its pushing the wheel out further from the hub?
Hmm someone (JRL?) posted a wheel fitment template a few months back. Maybe someone can remember the title of the post.
It's in the Modifications Index Sticky. I've actually made an updated template to JimLil's original.
Here's the link
http://forums.swedespeed.com/showthread.php?13579
Aside from the caliper, everything else should fit, ET 42 front is pretty much standard R offset. As silverbullit mentioned, spacers are an option if they don't clear the calipers. Using both 5mm and 10mm spacers are still within the physical limit of the R without rubbing.
1 - 6 of 6 Posts
