My parents have an extra 14inch Harman Kardon Subwoofer meant for a home theater.
Would it be possible to mount in my s40?
Re: Could I hook up a home theater sub into my car? (Kallvin22)
Quote, originally posted by Kallvin22 »
This is all I can imagine...
Re: Could I hook up a home theater sub into my car? (Vash13)
Quote, originally posted by Vash13 »
Haha well I would take the mesh covering off! IT would appear to be a regular sub =]
I beleive the home speakers have a difference impedence atleast they used too.
Yes! It is absolutley possible, works and did it for a buddy of mine in his little getto ride here in Turkey... You will a power inverter with enough wattage to be able to power the Sub Woofer get twice what the sub requires. You can get one that wires directly to the battery or one that utilizes the cig lighter... Then you will need to run a set of pre amp outs to the sub if the sub uses a single input just get a reverse splitter... http://********************/smile/emthup.gif
Re: Could I hook up a home theater sub into my car? (kmg_S60R)
I helped put one in my friends Explorer once... it worked just fine!
Very possible.
You just need to know that home theater stuff is at 8 ohms. While car stuff is at 4 ohms impedance. So you'll need an amp that puts out double the power. (when rated at 4 ohms most are)
