Would appreciate feedback on how air suspension is intended to work while in park with engine on or off. Specifically, my dealer believes there may be a malfunction (so do I) as it relates to when it lowers or raises when parked (not during driving/moving). (Easy entry/exit is turned on in settings). My air suspension starts raising and lowering the car after someone exits after about 15-20min its moves up and down all by itself. Unclear how often this happens once I leave but may be the cause for low battery charge.
When engine is turned off it should lower car to easy exit (unless you open the door while its lowering then it stops) but should immediately resume after you close door but then no longer move until you get in the car again. Is this correct?
I've noticed mine moving a bit well after shutting off the car, I believe it is leveling itself. I'm not really sure but either way it has not caused battery issues on my car at 12k miles.
ok thx...manual does say 'level may be adjusted for a certain time' once parked to compensate for temp changes in the pneumatic suspension..question is how long/often should this occur.
