1 - 9 of 9 Posts
While looking for a leak in my coolant reservoir tank I removed the level sensor. After re-inserting the sensor the coolant level warning light remains on. What have I done and what should I do to correct this situation?<p>Thanks<br>Cypress<br>
Re: Coolant reservoir (cypress)
I have the same problem. In my case I found that the floater inside of the reservoir seems a sort of stuck in the bottom position, or not floating. When I pull it up with a wire hook - the light disappears, which means that the sensor is working properly, but the floater tends to drown somehow.
Re: (cypress)
At least it works for you, I wish I got the same result <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/frown.gif" BORDER="0"><br>I pull it up - the light stays off for a bit, then comes back on. Dang! I'm thinking about removing the signal bulb as an ultimate fix
Re: (d_man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>d_man</b> »</i></TD></TR><TR><TD CLASS="quote">At least it works for you, I wish I got the same result <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/frown.gif" BORDER="0"><br>I pull it up - the light stays off for a bit, then comes back on. Dang! I'm thinking about removing the signal bulb as an ultimate fix</TD></TR></TABLE><p>Uhm, why not replace the sensor and do it the right way? <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/wink.gif" BORDER="0"> <p>Cheers,<br>Prospero
Re: (Prospero)
It IS working, it's just that stupid floater inside of the tank will not stay afloat (or sticks in the bottom by some reason). I replace a sensor - I get the same red light. I need to try to remove the floater and see what's wrong with it<br>
Well, I spoke too soon. Same problem as yours. I've just got through draining the reservoir and fiddling with float. By the way, I found the leak. It was on the rim. I repaired it with a product called "Plastic Weld" from Auto Zone. I've got my fingers crossed.
1 - 9 of 9 Posts
