I'm parting out a complete Volvo V8 swap, if you see something you need email me. You can reach me @ four two three - seven one six - five three two zero Thanks Scott
Converse 5.0 Conversion Parts, comes with front cross member, motor mounts, trans mount, drive shaft, bbk headers, power steering lines, and complete 3" exhaust no cat, has two mufflers and is quiet. $500.
Bumpers, front, rear, and both side skirts $200.
E-Code Headlights, comes with both headlight, lower trim, turn signals, grill, and the wiring harness to adapt into you stock harness. The one has a very small hole about half the size of a BB. $200
Jamex Springs $150
Autometer Phantom Gauge Set, This is an awesome setup, has high beam, turn signal, and check engine indicator light in the panel. $400
Complete Black Interior, everything is in good shape, the dash is perfect, has 940 front seats and belts, carpet, door panels, console, plastic trim, sunvisors, are all included $300
Side Mirrors, pair, the mirror glass needs cleaning. $50
Tail Lights, with Decor Panel $100
Hood $75
Fenders $50 each
Trunk $50
Doors, with glass, and handles, rust free $50 each
Drivetrain Parts
1993 302 Roller Shortblock - doesn't smoke, leak, or rattle, installed into a Volvo V8 conversion, includes oil pan, dipstick, balancer, timing chain, and cover $250 SOLD
Front Accessories - Includes new Mecham 220amp Alt, PS, AC Delete, water pump, belt and bolts $150
Complete Distributor with Motorsport Wires $80
Complete Tremec 3550 - includes flywheels, clutch, pp, trans and Pro 5.0 shifter $900
Factory Harness and Computer $125
All the parts below were bought in late 2010 and have less than 9k miles on them.
185cc Aluminum Patriot Freedom SBF Head's - includes ARP Bolts, KMJ Performance Roller Tip 1.6 3/8" stud mount Roller Rockers, Edelbrock Hardened Steel Pushrods $700 SOLD
Venom: Poison 24# Injectors (orange top) $125
73mm C&L MAF Housing (Sample Tube Tuned to 24# Injectors) $100
Ford Motorsport Tall Valave Covers $100
70mm BBK PowerPlus Throttle Body $175
SCT Eliminator Chip (4 Tune Selector, Cigarette Lighter Switch ) $200
Comp Cams Xtreme Energy XE264HR Stage I Camshaft $175 SOLD
K&N Filter $30
Accel TFI Coil $40
Trick Flow Track Heat Upper/Lower Intake $350
Jamex Springs $150
Hood $75
Fenders $50 each
Trunk $50
Drivetrain Parts
K&N Filter $30
Accel TFI Coil $40
