It started like this. Front right control arm bushings were worn out (at 56K mi). It was easier to replace the control arm than the bushings. In the process, the axle half shaft was broken at the CV joint, which was not detected until the car was road tested (and then very quickly). After about 20 feet of attempting to drive, the car would not move, and the message window indicated a traction control problem.
After pushing it back into the shop and replacing the half shaft, further road testing revealed the car had become FWD only (the AOC clutch was never engaging). A code was present for the AOC control module, which was replaced (for $2600).
After replacing the control module, with no codes present, the AOC clutch is now fully engaged all the time. Tight turns, such as into or out of a parking spot, with all 4 wheels turning at the same speed, makes for a very uncomfortable experience.
The entire AOC at wholesale prices will be $4600. I found a used one with 25k mi for $1100. Why did I let you talk me out of the extended warranty?
