1 - 9 of 9 Posts
Hello everyone,
I have a Volvo V70 2.0t and I want to change all the seats in my car.
Do you have which seats are compatible with my V70?
Thanks a lot.
Since you didn't say the MODEL YEAR of your car, no we can't
Like Jim said depends on year. P80 seats outside of the proper range for your car can be swapped but it's not plug and play.
My Volvo is from December 1998
I believe you have a 99 model year then. Any build date 8/98 - late 2003 seats use the same harnesses. P2 seats can be bolted to the p80 adjuster/electric seat assembly as well.
You just can't use earlier seats, M/Y 1998 and earlier. The side airbag wiring is completely different.
Mechanical vs electronic deployment. You can fool the ME7 SRS system into being happy by wiring in a resistor where the airbag used to plug in and the mechanical sensors will still work fine. I don't think there is a way to make this work in the other direction though.
1 - 9 of 9 Posts
