Guess i should start keeping track of my progress....since i have neglected to for over a year :)
snow vooo
here she sits next to my friends STi....p2 is faster :thumbup:
heres my recent order
120806 Spark Plug Cover Bolt Kit Blue 1 X $58.00 = $58.00
121092 LED License Plate Illumination Kit 1 X $11.95 = $11.95
107936 Cabin Pollen Air Filter Element P2 S60 V70 XC70 S80 XC90 1 X $11.00 = $11.00
121131 IPD HD Diverter Valve Polished - S60R V70R 1 X $259.99 = $259.99
115396 Economy Trunk Lift Support Shock P2 S60 1 X $14.18 = $14.18
111082 Headlamp Wiper Blade Set P2 S60 V70 XC70 1 X $13.35 = $13.35
115018 ipd HD Ignition Coil with 96mm Insulator Boot 5 X $54.95 = $274.75
114200 Fuel Filter 1 X $38.75 = $38.75
120685 Turbo Inlet Hose Blue - P2 S60R V70R 1 X $249.00 = $249.00
120708 V-Band Adapter K24 Turbocharger - S60R V70R 2004-2005 1 X $64.95 = $64.95
120705 Silicone Performance Charge Air Pipe - P2 S60 V70 XC70 1 X $369.00 = $369.00
112455 Hood Support Shock 2 X $9.40 = $18.80
113555 Volvo Spark Plug Set (Turbo) 1 X $54.87 = $54.87
plus a blocking flange for the cbv from viva and new silicon vacuum lines
and a 12 pack of beer...a necessity while wrenching
started with the fuel filter...i believe it was the original
hit the pressure release
deff the original look at that ****tt
next was on to the LED license plate lights
before
after
next was the cabin filter....my AC smelled like poop
heres why..
few days later brought it to my buddies house...he has everything
my boy ray's 04 cobra
tranny was pulled....blown t-56
he doesnt mind helping me with my R ....thinks they are nasty, pretty cool :D
both are soooo sexy
next was new ipd HD coils and new oem plugs
i had a cylinder 3 misfire heres why....look at all that soot
and then WTFFFFFFFFFFFFFF.....im going to the dealership and getting a free set of plugs...did these less than a year ago and ive NEVER seen this!!!!!
next was getting in Vivas CBV blocking plate.....took every thing out
THERE IS NO NEED TO ROTATE THE TURBO TO DO THIS !!!!!!!!!!!!!!
ALL YOU DO IF PULL THIS COOLANT LINE
heres there heater hose that you pull
you can see the CBV blocking plate there
you only loose about a half quart of coolant
putting here back together home strech.....new OTE pipe..Vac lines.......and the IPD diverter valve
finally done!!!
ill post a diverter valve write up at some point
more mods to come
Holy ****....that spark plug most likely caused some damage.... You should do a compression test man
By the way they look like they have never been replied....unless you do 100k a year
I changed the plugs less than 10000 miles with volvo oem .....and I hope not.....car runs great now pulls hard....I guess time will tell
The plugs are still under warranty too ....some I'm gonna get a free set
