1 - 10 of 10 Posts
The car is a '98 V70 AWD LPT with a 16T turbo and injectors. It has been tuned for those parts but did overboost a few months ago right before this issue started.
For the first 1-2 minutes after a cold start I hear the sound in the video. After that I never heard the sound again until the next cold start. I tried Rislone and MMO with no success. I had the oil pan pickup seals replaced but that didn't completely fix the issue but may have improved it a bit. I'm using a Mann oil filter and 5w-30 oil. Using heavier weight oils haven't helped so far. I'm not sure what else to try at this point.
Oil is light and the motor is hydraulic lifter. Normal behavior.
Ditto on the oil getting up to the lifters. Sometimes the noise getting louder is a signs that the o-rings in the oil pan pick-up need to be replaced.
Yes, normal. Would you try some flavor of 0W-30? (Flame suit on, can of worms? I sure hope not.)
Just don't put in anything that says "Lucas" on it, please.
Those have been replaced this month. I could try a 0w-40 oil next oil change.
I would. Maybe Pennzoil Ultra, or Pennzoil Platinum. The Mobil 1 0W-40 always used to be readily available at Walmart in a 5-gallon jug for $25 or less, the Pennzoil, if you can find it.
If it's warm out, you should be able to try a 5W-40 also. Sometimes they have the Pennzoil of that grade. Certain oils quiet motor noise better, Pennzoil has a lot of reviews of "quieting an engine" if you want to call it that.
I have the same issue with my car, it's most likely the oil or the lifters. I'd try 0w-40 and then go from there, hopefully it resolves for you! My seals are in need of replacement :(
Another oddity to me is that the sound is completely absent on warm days. Though I had to wait until we had a few warmer days to confirm this. It's 70 degrees today in the shade. The car hasn't been started in two days. I fired her up and no tapping noise whatsoever. If it was 40-50 degrees out I'm certain I'd hear my tapping noise.
1 - 10 of 10 Posts
