1 - 6 of 6 Posts
Im have 2 codes poping up fuel bank trim 1 the catalyst system any help identifying what that could mean would be helpful thanks
What vehicle? Year? Engine? What are the actual codes?
Total guess but failing injector and or failing catalytic converter -- or possibly failing O2 sensor. The computer varies lean/rich based on the MAF and output O2. It expects a certain amount of O2 variance between readings before/after the cat which is how it tests cat efficiency (that it is still working).
2006 volvo s60r 2.5l turbo awd not sure the exact code but its telling me Fuel Trim Bank One and Catalyst system is all is says but i cant rember the codes
If you have a reader, please post the codes. Google is also a good source...
1 - 6 of 6 Posts
