So I just so happened to finally run the full diagnostics on my car (06 s40 2.4i) and (app officially released full version on my phone) and codes just popped left and right.
When i went to turn off car key was stuck between 0 and 1, the display wasn't even picking up what gear i was in.... When it has worked up until this point.
Husband drove it around, looked under the hood, pressed gear shifter down and changed gears as he did this, and it started working again.
Are we looking at a wire or.... No...? Photos (screenshots) to come next...
A/c issues im aware of... Hubby removed fuses until we replaced the compressor/clutch.
First I would unplug the battery and let it chill for 10 minutes. See if that clears things up.
Then get the battery tested. If it's pushing 5 yrs old I would plan on replacing it.
