I want to know what this code means.
i know it is either the O2 sensor or it could be the cat.
"catalyst system below efficiency threshold. "
has anyone with XC90 2.5 dealt with this?
how could i know if it is the cat or the O2 sensor. if so which sensor would it be?
car drives fine!
This is the generic OBD-II code that relates to the catalytic converter. You should have a shop remove the catalytic converter and O2 sensor and inspect the cat for damage or clogging. If that is fine, order a new O2 sensor which should cost about $100 (rough estimate). If the message still does not go away with a new O2 sensor, then your catalytic converter has failed. You can either purchase a new OEM one ($$$$$$ but legal in all 50 states), purchase an aftermarket replacement cat ($$, but only legal in 48 states), or get it tuned by Rica, IPD, etc and have them turn the light off for you - which I consider the cheapest and most cost-effective option.
mmmmm ok thanks. i guess ill go from there. I saw the OEM cat is 400-500 no thanks.
if i have to replace it do you know of a good aftermarket brand?
and when you mentioned, " get it tuned by IPD or Rica. " you mean the aftermarket Cat that i buy.
send it in and get it tuned?
why would it throw a code? no O2 sensor ?
sorry for the questions. thanks
