1 - 16 of 16 Posts
<IMG SRC="http://images.cardomain.net/products/nie/NIE2000005_1.jpg" BORDER="0"><p>This is the one from NX express I saw one on a WRX he said it worth it just useing that you feel a gain in power <p>How it works for those who might not know it sprays on the out side of the intercooler dropping the temp of the air and make the air more dense meaning more air in
Re: CO2 intercooler fogger anyone try it (zzrguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>zzrguy</b> »</i></TD></TR><TR><TD CLASS="quote"> <IMG SRC="http://images.cardomain.net/products/nie/NIE2000005_1.jpg" BORDER="0"><p>This is the one from NX express I saw one on a WRX he said it worth it just useing that you feel a gain in power <p>How it works for those who might not know it sprays on the out side of the intercooler dropping the temp of the air and make the air more dense meaning more air in</TD></TR></TABLE><p>It's not a CO2 fogger, it's a Nitrous Oxide NO2 fogger. <p>I'd like to see the dyno sheet that says this thing can make an additional 52 horsepower on a car....were they testing the car in 120degree ambient temperatures? <p>I'm sure this would have some effect....spraying cold gas on the front of the intercooler would lower the temp of the fins and lower the temp of the air passing through. However, given the position of the stock intercooler, I dont' think you could even install this thing on a stock R.
same thing I have, just use the bottle for nitrous. Nitrous works much better but CO2 is way cheaper to refuel.
Re: (R_Rated)
Yeah but you've got a true FMIC. <p>The amount of flow that goes through the stock "helper" IC is pitiful. To have any noticeable effect I have to imagine you'd have to rip the front end off and sandwich between the condensor and main IC.<p>You might as well just go the extra step and rip them both out and install a FMIC and take a pass on the CO2 until later if the FMIC isn't sufficient.
Re: (StaggRLee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>StaggRLee</b> »</i></TD></TR><TR><TD CLASS="quote"><br>You might as well just go the extra step and rip them both out and install a FMIC and take a pass on the CO2 until later if the FMIC isn't sufficient.</TD></TR></TABLE> <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> <IMG NAME="icon" SRC="http://********************/smile/emthup.gif" BORDER="0"> <p>definitely. There is <B>NO</B> intercooler spray that is worth the trouble on our cars without doing an FMIC <B>FIRST</B>. If you are concerned with cooling and do not want to do an FMIC get the aquamist.
Re: CO2 intercooler fogger anyone try it (needsdecaf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>needsdecaf</b> »</i></TD></TR><TR><TD CLASS="quote"> <p>It's not a CO2 fogger, it's a Nitrous Oxide NO2 fogger. <p></TD></TR></TABLE> <p>The description stated you could fill it with ether CO2 or NO2
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>zzrguy</b> »</i></TD></TR><TR><TD CLASS="quote"> <p>The description stated you could fill it with ether CO2 or NO2</TD></TR></TABLE><p>this is correct. both will freeze the intercooler.
Re: (StaggRLee)
Is it possible (of course everything is possible, but not necessarily economic) to move the R intercooler in front of the condenser?<p>I have not seen anyone talking about this, so I guess not?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>zzrguy</b> »</i></TD></TR><TR><TD CLASS="quote">is it worth it for my 2.4t</TD></TR></TABLE><p>You're undoubtedly running the exact same core and piping on a 2.4 LPT that is used on a 2.5 HPT. You've probably got more than adequate cooling for the boost levels you're running.<p>Guestimating that kit at $500, labor to insert it between the condensor and IC at another $500... There's a lot better ways to spend $1000 IMO.
Re: CO2 intercooler fogger anyone try it (StaggRLee)
ITs $399 and I put it in my self is there a way to crank up the boost on the 2.4t
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>zzrguy</b> »</i></TD></TR><TR><TD CLASS="quote"> <p>This is the one from NX express I saw one on a WRX he said it worth it just useing that you feel a gain in power </TD></TR></TABLE> <IMG NAME="icon" SRC="http://www.vwvortex.com/zeroforum_graphics/screwy.gif" BORDER="0"> Could you please repeat this is <U>english?</U> <IMG NAME="icon" SRC="http://www.vwvortex.com/zeroforum_graphics/screwy.gif" BORDER="0">
have you done an ECU upgrade? if you want more power - i think the best first mod on any turbo volvo is to upgrade the ECU
Re: (23109VC)
Actually, the "pre coolers" like the one on R have shown to be very effective as being a heat sink that saves the ic from being heat soaked too quickly. Solid enginering is why its there. (I've seen/done data logs)<p>Not saying improvement can't be made though and I would say that it would not be too much of a stretch that you would see some nice gains in say a 1/4 mile drag or maybe a just 3rd-5th gear run.<p><B><I>DO IT</I></B> (Ben Stiller)<p>but...<br>Agreeed, if you are still on stock boost, probably shouldn't bother with it.<p>And..<br>A <I>better</I> FMIC is still a better more long term application.
Neither CO2 nor NOx are Al Gore approved. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0"> <br>
Re: CO2 intercooler fogger anyone try it (ljjones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>ljjones</b> »</i></TD></TR><TR><TD CLASS="quote">Neither CO2 nor NOx are Al Gore approved. <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/smile.gif" BORDER="0"> <br></TD></TR></TABLE><p>neither is the interweb and he invented it <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/sly.gif" BORDER="0">
1 - 16 of 16 Posts
