(With no radio on) I hear a clunk in the front driver's side when engaging and disengaging the cluctch, most notabley in the lower gears. What could this be attributed to?
Moderator
Re: Clutch engagement and disengagement (bigwill5112)
Could be two things: <p>lower Transmission Mount <p>Or<p>Axle ping <p><br>After replacing my lower transmission mount, my noise was reduced a bit, but still remained. Now I ordered XC90 bolts which should eliminate the axle ping (part # 30714142). It's a very common failure from what I've been reading
Where did you get your mount? I put the bolts in two days ago and it got rid of the ping, but I still have a clunk.
Moderator
Re: (bigwill5112)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>bigwill5112</b> »</i></TD></TR><TR><TD CLASS="quote">Where did you get your mount? I put the bolts in two days ago and it got rid of the ping, but I still have a clunk.</TD></TR></TABLE><p>I got the IPD poly mount.
Re: (tomedkaz)
<A HREF="http://www.ipdusa.com/Volvo-S60/Engine/Engine-Mounts/Heavy-Duty-Polyurethane-Transmission-Mount/p-74-392-761-3330" TARGET="_blank">http://www.ipdusa.com/Volvo-S6...-3330</A>/
