Does anyone know if a cluster from a 2008 & up will work in a 2005 ? My daughter says the mph needle will sometimes freeze or not register at all. All the other gauges work fine.
Yes it should. But just know if you swap in a cluster from a lower mileage car I believe it takes whatever mileage was lower(?). You can search around on that but the cluster should work no matter what year.
IMO you'll be much better off repairing the original. The DIM stored mileage is compared with a copy stored in the CEM and the "mileage tampered" flag will get set, if not the immobilizer.
Thanks for the replies if it doesn't start I'll just swap the stepper motor. I figure for 30 bucks its worth a shot.
