I get a strange clunk noise when i go over bumps in the morning, after about 10-15min of driving th noise just goes away. Should i be worried?<p>Also my Service light is on if i change my own oil will it go away?
Re: Clunking noise from front passanger side? (zdsquared)
<br>Re: Service light, 2 options, use one of the plug in units to check the code and fix OR open the fuse box (the small one, not the main one) and unplug all the fuses (5 of them) for approx 30 seconds. That will reset. If it lights up immediately - YOU HAVE A PROBLEM. GO PASS GO, DO NOT COLLECT $200, Take it to Volvo ASAP. <p>Good luck.
Re: Clunking noise from front passanger side? (Toronto1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>Toronto1</b> »</i></TD></TR><TR><TD CLASS="quote">Re: Service light, 2 options, use one of the plug in units to check the code and fix OR open the fuse box (the small one, not the main one) and unplug all the fuses (5 of them) for approx 30 seconds. That will reset. If it lights up immediately - YOU HAVE A PROBLEM. GO PASS GO, DO NOT COLLECT $200, Take it to Volvo ASAP. <p>Good luck.</TD></TR></TABLE><p>Actually it's "Do not pass go and do not collect $200.00." <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0"> <p>The service light is different from the Check Engine Light and to answer the question...no it will not reset itself after changing the oil; the light needs to be reset with a service light reset tool if you have a 1998...if yours is newer then there is a simple sequence to do. <p>The clunk could be many things and it's hard to figure without a better description of when, where, how, and why. Odds are you have a common End-Link issue...but it could be something else as well.<p>Good luck and cheers,<br>Prospero
