When I go around a corner at low speeds I can hear a couple of clunks from the rear. What should I look for when I check underneath?
broken sway bar end link maybe?
do you hear it over speed bump?
Even if the end link bolts are loose the rear will make pop or clunk sound. Time to get under there and check it out.
Not over speed bump, just going around a corner 10-15mph. Drove the back on to ramps and went underneath to grab and shake all suspension bits but didn't find anything loose. Do I have to check with the wheels hanging down?
My trunk cover, flipped down when top is retracted, will make noise if not put in full upright position when top is up. Road bumps will cause a thump or rattle sound.
