1 - 9 of 9 Posts
Hello all: I recently began noticing a clunking sound coming from the front end usually when I'm turning into a driveway. I took it to the dealership, who told me that such an clunk is natural for S80's. I was also told that the suspension points all checked out. That just doesn't sound right to me. In fact, the clunk seems to be getting louder. (By the way, I have a 2007 3.2 with 30k.) Thanks in advance for your input.
Re: Clunk in front end (zachsdad)
Sport Package?
Yup. I have the same problem too. Dealer never could "replicate the problem". It happens when turning on a slope, and gets worse in cold weather for me. If you figure out what is wrong, let me know! <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/tongue.gif" BORDER="0">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>zachsdad</b> »</i></TD></TR><TR><TD CLASS="quote">... who told me that such an clunk is natural for S80's...</TD></TR></TABLE><p>That's a euphemism for "we don't have a clue what's wrong". <IMG NAME="icon" SRC="http://www.vwvortex.com/vwbb/biggrin.gif" BORDER="0">
I hear it all the time. No idea what is it.
Same problem for me. I have an '07 S80 V8. I only hear it in cold weather and only when I first turn through a slope or bump after starting the car - after it makes the knocking sound once I don't hear it again until I start the car again after sitting overnight. My dealer didn't really have a clue.
I found this info on a first generation S80 board. Perhaps, it might give some insight:<p>1999 S80 2.9 Front End Clunking Noise<br> <br>Do you have clunking you can feel under your brake foot at low speeds and in turns? You can add two large “o-rings” to take up any slack in the bushing of the subframe and eliminate the clunking. You will need two o-rings and two new bolts. Part numbers for the parts to fix this are listed in the thread. <p>The thread is posted below.<p><A HREF="http://www.matthewsvolvosite.com/forums/viewtopic.php?p=31628" TARGET="_blank">http://www.matthewsvolvosite.c...31628</A><p>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>zachsdad</b> »</i></TD></TR><TR><TD CLASS="quote">I found this info on a first generation S80 board. Perhaps, it might give some insight:<p>1999 S80 2.9 Front End Clunking Noise<br> <br>Do you have clunking you can feel under your brake foot at low speeds and in turns? You can add two large “o-rings” to take up any slack in the bushing of the subframe and eliminate the clunking. You will need two o-rings and two new bolts. Part numbers for the parts to fix this are listed in the thread. <p>The thread is posted below.<p><A HREF="http://www.matthewsvolvosite.com/forums/viewtopic.php?p=31628" TARGET="_blank">http://www.matthewsvolvosite.c...31628</A><p></TD></TR></TABLE><p>Not sure this is valuable since the cars are completely different from top to bottom.
1 - 9 of 9 Posts
