1 - 11 of 11 Posts
I get a clunk or knock every time I let out the clutch or step on the clutch when in gear. No clunk in neutral. Would this seem to be suspension issue like strut mounts, or maybe engine mounts?
Check your torque bushings for any tears there’s one above the engine on the strut brace and one below the engine attached to the transmission and subframe on the drivers side.
yup, likely the engine and transmission torque mounts. The rubber on them ages very poorly, and eventually get enough play that you get a "clunk" sound. Especially shifting between gear and reverse.
The one above the engine: http://i.ebayimg.com/images/i/131161311501-0-1/s-l1000.jpg
The one tied to the transmission: https://i.ebayimg.com/images/i/220994559833-0-1/s-l1000.jpg
Very easy to replace, some people go for stiffer and more durable polyurethane bushings: https://volvo850wagon.files.wordpress.com/2012/02/dscn7686.jpg
Sure, depends on type of noise. May also be flywheel, throwout bearing. How many miles on clutch? VR M66? Just sell it :D
1 - 11 of 11 Posts
