Hi All,
My 06 xc90 is in the shop right now for a leak in the AC Condenser. The service rep said that they would recommend taking care of a climate control module software module at this time as well. it would give me two things. 1) i might be paraphrasing this wrong but she said the system would run an "afterblow" after i turn the car off to exhaust any moisture in the ducts and car. and 2) it would upgrade the damper control system. this would help out with another a problem i noticed where the passenger vents are colder then the driver even when the temps are set at the same. apparently this fix is not covered by warranty because its software and not a damaged part.
The cost on the software upgrades is $130... the ac condenser work is covered by extended warranty.
has anyone had this afterblow software upgrade offered to them? has anyone else had to pay for software upgrades to fix a damper problems?
thanks
thanks
