help please.
A brief noise from the passenger door, of my 04 xc70 occurs when I push the lock/unlock button. It just started today. I can manually lock the door from inside. When I push the unlock button, the door remains locked.
Is it a fair assumption for the actuator to be bad? Is there any other moving parts that could be stripping out or grinding? Id like to get a clear picture and game plan and parts, before I tear into it.
I did search the site, and in the xc90 forum is a good write up on replacing actuators. Would the xc70 door be similar or the same.
Thanks in advance...
Greg
If it's still clicking and buzzing, it may just be jammed or need lube. My driver's door actuator just stopped one day and makes no noise of any kind. I'd pull it out and see if you can spot any problems. Although I recommend getting a replacement anyway so that you don't have to tear it down twice if it really is dead.
