1 - 6 of 6 Posts
Any time i accelerate i hear a click. Then also sometimes when i come to a stop. I was thinking it could be the upper motor stabilizer but now thinking different since bushing looks fine. Anyone have an idea?
Axle ping. Lookup XC90 axle bolts, it solved the same problem I had that you described. ;)
+1 on axle ping. Just replaced mine with xc90 bolts.
50nm for the XC90 bolts.. i have them, they work great
might be worth noting...
XC70 calls for 70Nm with original axle bolt
S60 calls for 30Nm, then angle tighten 90* with original axle bolt
I still have original axle bolts on the XC70 and they dont click even after I've taken them off and re-tightened them.. they appear the same design as S60. So maybe tightening original S60 bolts to 70Nm will stop the clicking? If anyone is willing to try? :p
1 - 6 of 6 Posts
