So, I put volvo pegasus wheels with Yokohama h4s 235x45hr17 on this 2001 s60 (not the R model) and I have wheel rub inside the wheel well when I turn hard either way.
Suggestions on what to do?
Thanks,
Don
Re: clearance problem on 2001 s60 with 235x45x17 tires (dgpach)
5MM spacers.
Most tires this size WILL rub, The car was never really designed for this large a tire 225's work better
This is one reason why Volvo uses Pirellis, narrow tread shoulders as most other tires rub. Try the spacers, they work for me
Re: clearance problem on 2001 s60 with 235x45x17 tires (JRL)
Thanks This helps alot. I assume that the standard lug bolts don't need to be replaced for only a 5mm offset?
