Hello,
I need some guidance to properly remove the chrome trim at the base of the door window without breaking the clips.
Many thanks.
Use this type of nylon trim tool set. Prevents scratches.
Pry ever so gently, start with the far end near the door handle.
Push out with tool and use finger to pull up gently and work your way forward.
As you pull the chrome piece, do not pull at the far end. Always pull on the section closest to the sheet metal.
Most delicate part is at the end, under the mirror. Take your time!
Thanks dude. I finally managed to do it. Basically, the trim is secured by two clips at both ends that you need to pry them out super carefully. The rest are rubber sheets holding to the door panel that needs to be lifted upwards.
