1 - 2 of 2 Posts
About five months ago, I replaced the fuel filter. I used to have hesitation until I replaced the fuel filter. All went well until about two months later, the hesitation started when applying gas as to overtake a car on the highway. It got worse with time. Now, the car won't start.
Any write-up on checking everything 'fuel'?
That is, from the Filter, Injectors, Regulator, Valve, Pump and any other fuel related write-up one might have.
What if the tank is dirty?
Thank you.
Check all the turbo plumbing. If you have a hose loose(boost leak) the car will hesitate to accelerate. If a hose has fallen off, the car won't start.
EDIT: This topic is in the wrong section of the forum.
1 - 2 of 2 Posts
