Well I've only had the car a few days now and already I have a check engine light on, I just pulled the codes and got PO507 IAC system,idle higher then expected, does any one have any idea what could be causing this? Thanks
There is no IAC. It has an ETM. "P0507 -- ECM-951C -- Engine control module (ECM), idle control -- Signal too high"
Look for intake leaks.
Well technically on it's an ETA but it's the electronic throttle module. The car is drive by wire.
