My T5 is showing P0455 - Evaporative emissions control system leak detected - gross leak. Came on this morning.<p>I searched and found one thread on here that suggested gas cap (I'm near the bottom of the tank though, and I always go 5-6 clicks). Other suggestions were purge valve and a cracked canister line.<p>Any advice on the purge and canister line thing, or other suggestions? Does the gas cap thing happen at any point during the tank, or mostly soon after fill up?
Filler up and click it again...see if the code disappears in about 50-100 miles. If not, then check for leaking hoses and the purge valve (about $20)...it's the one with the purple line coming into it just at the top of the radiator on the driver's side (may be different on your car- it being a '99). It has a white air-lock attached right before it. If that doesn't work, then we're talking more stuff, like the purge canister, which is below the car, closer to the gas tank.
Thanks for the info. I'm due to fill up today, and will check under the hood as well.
CEL went away, must have been the gas cap :|
