Well, the battery might not be the problem after all. I got the battery exchanged because it was not holding a charge and had only 120 CCA showing. But driving home after putting in the 2nd battery, I saw the "Low Battery Voltage" warning appear in the screen. I really doubt that 2 batteries in a row are bad. I just took it to the dealer because I was fed up with trying to figure it out, but what could possibly be bad? I had the alternator checked and it was putting out around 13.14 volts. That's normal range, right?
