1 - 2 of 2 Posts
No, not at all. Open the hood & you'll see a phillips screw just to the outside of the headlight assembly. Just loosen the screw a little (don't remove it). Then press the small grey tab next to it & slide the whole assembly forward. You can then remove the bulb socket from behind.
I know this isn't very detailed, but it should all be explained in you owner's manual under "replacing bulbs".
[This message has been edited by robertag (edited 07-30-2001).]
1 - 2 of 2 Posts
