Discussion Starter #1 (Edited)
Changing the brakes at XC90 2.5T
In next 2 months I plan to refurbish my 6 years old XC90 2.5T VOR with some Heico products and I need also your opinion regarding the brakes.
I suppose that this kit including the front and rear brakes sets ?
In description is also written:
Details
- including stainless steel brake pipes front and rear
p.s. this is the products what I will order:
HEICO SPORTIV sport brake kit (6-piston) XC90
http://www.heicosportiv.de/nextshopcms/cmsimage.asp?fkt=3&id=8383
Discussion Starter #2
I get answer from Heico:
most of the sport brake kits on the market are only for the front axle , because 80% of the brake performance is on the front axle !
What you get is: 6-piston calipers, 370mm discs, brake pads, steel flex brake lines (brake lines also for the rear for a better pressure point)
- deceleration values of over 10.35 m/s²
- braking distance 100-0 km/h = 35,4 m (Volvo = 41,2 m)
- fits with VOLUTION® VII. 19/20 inch or VOLUTION® X 19/20 inch.
The new sport brake kit with aluminum calipers fitted with six pistons are a real eye-catcher with their blue lacquer glaze and HEICO SPORTIV logo; and perforated, internally ventilated 370 millimeter diameter brake disks provide for a better response in wet weather and improved heat dissipation. The result: excellent stability, deceleration values of over 10.35 m/s² and a much shorter braking distance than series-production vehicles.
Discussion Starter #3
Volvo service trenee put smaller disks LOL
And this happen when service guy put smaller disks.
I noted some strange sound after 2000 km...and check disks.
Reclamation was accepted. New disks and new braking pads.LOL :)
http://postimage.org/image/igljkfoif/
