2005 T5 AWD, I got the belt on and the tensioner adjusted, and it's hard to judge the rear cam timing mark position in relation to the notch in the belt cover. The front cam is easy to see and is correct. Does anyone know how many teeth on the belt there should be between the two marks before buttoning everything up? I don't want to have to take it apart again if it's off a tooth.
Front cam right on:
Back cam hard to tell from the angle of the picture:
Your exhaust cam is off by few teeth. If i was you i would redo it. Hopefully you didn't put everything back together?
