Hey everyone, i am planing on changing the collar sleeve and resealing the angle gear. i have all the seals for the angle gear but i was wondering if there is a seal between the collar sleeve and the transmission if so does anyone have the part number?
thanks
Oskar
977023 is what I believe is the O ring that goes down on the trans side splines and stops ATF from going into the collar splines. It just slides down and the collar crushes it against the final drive carrier behind the splines.
If you look in there you should see it.
Oh its just a o ring, I thought id be a bigger seal, thanks :)
There is a lip seal where sleeve goes into case to seal the outside of sleeve and the Oring to seal the splines on the trans side.
awesome, i wondering why my local dealership couldnt tell me this.
Thanks
