1 - 1 of 1 Posts
Discussion Starter #1
My owner's manual says that chains on the S40 should only be used with 195/55/15 tires, which is not a +1 size from the standard tire. Anyone try out chains using the standard 195/60/15's? I don't plan on buying a second set of wheels to use chains.<p>I myself usually use cables instead of chains anyways. I wonder if the manual meant that the same warning applies to cables as well.
1 - 1 of 1 Posts
