:: StopTech/Centric Cross/Drilled & Slotted Rotors ::
Hi, all.
I'm selling a complete set (all four wheels) of StopTech/Centric Cross/Drilled & Slotted Rotors for $675 (ish).
I am located in Portland, OR, but would be willing to ship if you are willing to split the freight charges with me
I can be reached via text at Five-oh-3.eighty-nine.3.Five.Thirty-three,Three:
MODEL: 127.39035L (front left), 127.39035R (front right), 127.39036L (rear left) & 127.39036R (rear right). These retail for upward of $250 EACH when you can find them in stock.
These rotors have never been installed. They are BRAND NEW and need a home.
More information on these rotors can be found here:
Package
Brand: Centric/Stoptech, Stoptech Brake Rotors FRONT
Part Number(s): 127.39035R, 127.39035L
Height: 2.2 in
Width: 13.5 in
Length: 13.5 in
Weight: 21.5 lbs
Driving Qualifiers: Performance Street, Normal Commute
Rotor Style: Cross-Drilled & Slotted
Rotor Coating: Coated
Rotor Material: High Carbon
Rotor Treatment: Non-Cryo Treated
ABS Tone Ring Included: No
Bearings Included: No
Center Hole Diameter: 2.677 in
Disc Mounting: Floating
Discard Thickness: 30.000 mm
Hat Finish: Coated
Mounting Bolt Hole Circle: Diameter 4.252 in
Nominal Thickness: 1.260 in
Outside Diameter: 330.000 mm
Overall Height: 51.000 mm
Rotor Type: Vented
Stud/Lug Hole Diameter: 16.600 mm
Stud/Lug Hole Quantity: 5
Surface Type: Slotted X Drilled
Vane Style: Pillar
Package
Brand: Centric/Stoptech, Stoptech Brake Rotors REAR
Part Number(s): 127.39036R, 127.39036L
Height: 2.9 in
Width: 13. in
Length: 13. in
Weight: 20.5 lbs
Discard Thickness: 26.000 mm
Hat Finish: Coated
Mounting Bolt Hole Circle Diameter: 4.252 in
Nominal Drum Diameter: 178.000 mm
Nominal Thickness: 28.000 mm
Overall Height: 2.559 in
Rotor Type: Rotor Vented
Vane Style: Pillar
Fitment
VOLVO S60
Year Make Model Trim Chassis Body style Engine Fuel sys Drive Transmission
2007 VOLVO S60 R P2 4 DR SEDAN B5254T4 ME7 AWD M66 AWD
2007 VOLVO S60 R P2 4 DR SEDAN B5254T4 ME7 AWD TF-80SC AWD
2006 VOLVO S60 R P2 4 DR SEDAN B5254T4 ME7 AWD M66 AWD
2006 VOLVO S60 R P2 4 DR SEDAN B5254T4 ME7 AWD TF-80SC AWD
2005 VOLVO S60 R P2 4 DR SEDAN B5254T4 ME7 AWD AW55-5X AWD
2005 VOLVO S60 R P2 4 DR SEDAN B5254T4 ME7 AWD M66 AWD
2004 VOLVO S60 R P2 4 DR SEDAN B5254T4 ME7 AWD AW55-5X AWD
2004 VOLVO S60 R P2 4 DR SEDAN B5254T4 ME7 AWD M66 AWD
VOLVO V70
2007 VOLVO V70 R P2 5 DR WAGON B5254T4 ME7 AWD M66 AWD
2007 VOLVO V70 R P2 5 DR WAGON B5254T4 ME7 AWD TF-80SC AWD
2006 VOLVO V70 R P2 5 DR WAGON B5254T4 ME7 AWD M66 AWD
2006 VOLVO V70 R P2 5 DR WAGON B5254T4 ME7 AWD TF-80SC AWD
2005 VOLVO V70 R P2 5 DR WAGON B5254T4 ME7 AWD AW55-5X AWD
2005 VOLVO V70 R P2 5 DR WAGON B5254T4 ME7 AWD M66 AWD
2004 VOLVO V70 R P2 5 DR WAGON B5254T4 ME7 AWD AW55-5X AWD
2004 VOLVO V70 R P2 5 DR WAGON B5254T4 ME7 AWD M66 AWD
Please ask any questions you may have.
Cheers.
No flakes .. no scammers .. no low ballers.
Simply put, PLEASE don't waste my time and I promise not to waste yours.
