How does this come out.........the one on top of the dash. Wanna run some GPS wiring.
Just pull. It snaps into the face of the speaker frame. If you pry on your dash it'll dent it, probably permanently, so don't do that. Ideally you want a thin hook that you can slide into the gap and then pull straight up. <p>I do use a screwdriver but I pry against my finger instead of the dash top.
Re: (LloydDobler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD><i>Quote, originally posted by <b>LloydDobler</b> »</i></TD></TR><TR><TD CLASS="quote">Just pull. It snaps into the face of the speaker frame. If you pry on your dash it'll dent it, probably permanently, so don't do that. <b>Ideally you want a thin hook that you can slide into the gap and then pull straight up.</b><p>I do use a screwdriver but I pry against my finger instead of the dash top. </TD></TR></TABLE><p>make you own from some scrap wire. stay away from prying, it's a good way to scratch the clearcoat.
