Hi,
so the purpose would be to change the cem to a newer module(upgrade to older non-facelift volvo)
so that I could use these features, but I am most interested in the DRL function
So, on that page the process is said to be easy and short because only the CEM and PAM itself are needed for the replacement/upgrade
This is what I don't understand and I would need help, when it is said that the cem should be "cloned", can I do it via obd? just for example using vdash and cloning from there? how else would that work?
Source:
https://www.drive2.ru/l/595978734037638813/
Source:
